Cannot get audio on one channel
Which make/model TV do you have? Are you watching an OTA signal or cable signal?
On my Viewsonic N1930W, I had a period where certain OTA VHF channels had no audio. The UHF channels were fine. The steps I used to reset the TV: unplug for a while. After reconnecting the power, go to the Tools (Options) menu and then reset the TV to the defaults. Then I did a new channel scan for OTA channels. On my TV, the menu is called Options but the icon is a wrench and a hammer in an X. Thus I call it Tools. The Restore Default option is at the bottom of the list in that menu. The reset command triggers several "Are you sure prompts?" Pressing the Enter key on the remote after highlighting Yes is required. After the reset, I can go to the Channel menu and select Auto Scan after making sure that it is set for Air as the source.
If you post a comment with the details of your TV, I may be able to give the steps to reset your TV.
I hope this helps.
(I spent several days trying different solutions and did e-mail Viewsonic support on the problem.)
I have installed a digiwave electronic master 3055 rotating ota antenna. It is up approx. 15 feet and I live below the escarpment in Stoney Creek on. and I cant seem to get any american channels, is my antenna powerful enough to pick up channels 95 miles away?
