I have turned the electric off and on with no effect.
SOURCE: Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
SOURCE: I have a Stoves Fan Oven Model no.059040414 which
It appears to be a wiring fault.
Suggest a job for an electrician
SOURCE: I require a new rubber
If you try www.buyspares.co.uk not sure if they do specific model but might do a universal seal for stoves
