I have a phase linear uv8. i got it all connected, tried the radio and it worked fine. i popped in a cd an it reads and even starts to play it, but not through the speakers
I have an amp & speakers hooked up to my phase linear uv8 and when i play the radio it plays loud & clear. But if I put in a movie or a cd it only plays through the car speakers & not the amp. What's up with that? I have an amp & speakers hooked up to my phase linear uv8 and when i play the radio it plays loud & clear. But if I put in a movie or a cd it only plays through the car speakers & not the amp. What's up with that?
You can't post conmments that contain an email address.
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Hola Hope this might help a little. You may have to read. Sorry, I can\'t post too many pics or video, but this link should help I hope. The link provides details and goes over the wiring. If not, google it or check on YouTube. Instruction Manual - Page 1 http://www.helpowl.com/q/Jensen/UV8/Technical-Support/phase-linear-uv8-schematic/9778
u need to get a Y splitter to make that one female into 2 females so both the red and blue plug in. its like 5 bucks. one end is a male rca connection then splits to to female rca's
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
you have a factory amp in your vehicle so what you need to do is take out the uv8 and make sure the remote wire from the unit " blue and whit stripe " is connected to the remote wire of the car harness.
the way you have it now is the power antenna wire " solid blue " the is connected to the remote wire of the unit
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
good call. thx
