Open clam-shell type case by pushing buttons on rear top and rear bottom of case and pulling case open like a book. Once case is opened, you\'ll see the hard drive in the right half (as viewed from the back of the PC) Pull the power and data cable from back of the hard drive. Squeeze ends of green plastic slides and pull hard drive from enclosure.
You need tools to open the computer case with Phillips screwdriver with appropriate size. Unscrew the 2 or 3 screw at the back of the case and then slightly slide the cover of the computer case to open. You will see the the hard drive screwed on the inside and unscrew and detach the power cord and data cable.
turn off the computer and unplug from wall open the case/tower remove wires from hard drive remove screws from hard drive remove hard drive and replace with new hard drive replace screws replace wires close up the case turn on the computer
In this case the hard drive is mounted in a frame. Look for mounting screws that locks this frame to the computer case. When you remove this frame you can access the screws holding the hard drive.
If you don't see any screw holes, look around for some rubber feet, chances are the rubber feet are hiding some screws. If you remove those carefully enough, you can easily put them back in. Once all the the screws are removed carefully pry open the case and remove/replace the hard drive inside.
If you are looking at the front of the computer case, you will need to remove the cover on the left hand side of the computer case. There should be two screws holding it in place, located on the back of the tower. Once you have remove the screws and cover, the hard drive will be accessible. Simply disconnect the cables to the hard drive and remove the screws holding it in place.
1. VITAL: unplug computer.
2 EQUALLY VITAL: wait for 1 full minute while board discharges.
3 open side of case.
4. VITAL ALSO: touch your hand to internal metal part of case to discharge static from your body
4 unplug old hard disk, then remove mounting screws from it.
5 remove old hard drive.
6 before handling new hard drive touch metal inside case again. (if you have a static band use it otherwise keep touching the metal case frequently to prevent static from "zapping" your computer parts.)
reverse this order to install new one. it will be recognized by computer on its own.
Step 1
Back
up your data. Make sure you back up any important data stored on the
hard drive in the event something goes wrong. Also, if you are selling
or giving the hard drive to someone else, you should erase any data on
the disk by formatting it.
Step 2
Open
the case. Remove any metal rings, watches or bracelets you may be
wearing. Unplug the computer from the electrical outlet, then touch the
metal casing to eliminate any static charge. You can also use an
anti-static wrist strap if you prefer. Check the user's manual if
necessary to determine how to open your particular PC case.
Step 3
Locate
the hard drive. Typically the hard drive will be connected to a flat 2
1/2 inch wide IDE cable and a power cable. Hard drives are often housed
in removable metal cages which are secured to the computer case with
one or more screws. Refer to your user's manual to locate the hard
drive if necessary.
Step 4
Disconnect
the hard drive. Unplug the hard drive from the IDE and power cables.
Grab the plastic IDE cable connector with your thumb and forefinger and
gently pull until the connector breaks free. The power cable can be
difficult to remove if the connector is fitted tightly. Make sure you
don't bend any of the pins when disconnecting the cables.
Step 5
Remove
the hard drive. If the hard drive is fitted in a metal cage, locate and
remove the screws that are holding the cage in place. Hold your hand
under the cage to catch it if necessary. Once the cage is free, remove
the small screws on either side of the hard drive to remove it from the
cage. If the hard drive is connected directly to the computer case,
simply remove the screws on each side of the hard drive and slide it
out of the case.
Remove the cover plate from behind the drive (where the plugs and on/off switch are.) You have to then remove the 2 screws. After that pull on the end with the blue lights to slide the hard drive out. If you have a tower computer, you can permanently install the hard drive and it should work fine as a secondary drive. Just make sure the jumper pins are set to "slave".
