SRIAL NO. ----------- TYPE NO. ----------- CODE NO. -----------
SOURCE: MURRAY AUTOMATIC DRIVE, 42
Your problem could be caused because your valves are not set properly (they vibrate loose sometimes. Remove your spark plug and try to crank theengine...If it turns freely with the pulug out, reset your valves..be sure to obtain the proper spacing (gap). Hope this helps
SOURCE: How can I detemine type of stator in my mower without disassembly
If you have two wires coming from under engine shroud, a black and red, plugged into a connector with a white and black wire going to the mower, It's a Dual Circuit alternator.
SOURCE: What type of oil do I use for a hydrostatic
Use a lo viscosity hyrolic fluid for you tractor and you will be good to go.
SOURCE: how do i replace drive belt on a gardenway lawn
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
