Unless you plan on using on-line subscription services (PlaysForSure) you can just flash it the UMS firmware.
WARNING!!!
If you install the UMS firmware you will permanently LOSE Janus support
(y'know, DRM subscriptions like Napster-to-Go) as you will NOT be able
to go back to the MTP firmware (at least as of yet...)
Also do note that For the T10 there is a strange glitch. After you
install the hacked firmware the player will not work at once. You will
have to flash it again, this time using the ORIGINAL UMS firmware from
iRiver.
If you are still willing to do it then go here http://www.mtp-ums.net/
then here is the link to the official iRiver firmwares
http://nyaochi.sakura.ne.jp/iriverupdate/
You will probably want
the EST (Australian) T10 UMS v1.62 (T10_EST_UM_OK) or the Kor (Korean)
ones... (T10_KOR_UM_OK)
I found it! I found it! I found it! :D I searched the whole internet for the damm cable and finaly found it on the korean iriver website. DO NOT! I REPEAT.. DO NOT BUY THE 24pin CABLE!!!!!!!! The Iriver Spinn needs a 20pin cable you can buy here:
iriver has problems with its video playback...
only certain formats can be played...
the iriver should have come with a converter on the provided program so just use that to convert the files to the format you need.
if that doesnt work try and get winavi converter.
I have a US model of the H320 - You have to update the firmware, but the US model only got to 1.04 and it sucks - go to http://www.misticriver.net/wiki/index.php/H3xx_Firmware_Version_Information and download the KOREAN version 1.31 version - it supports the US model. Once youupdate the firme ware on your H320, you will have to go the the main menu and switch the language to english.
