SOURCE: sgx skycaddie will not shut
perform a soft reset(a forced restart basically ) . hold power and joystick for 8 seconds. it will turn off. now turn on. if boots up correctly, then ok. if not, then perform hard reset.(remember that this will delete any information already installed..) push the information button (i) and flag button at same time. while both buttons are pressed turn on power. you should be in recovery mode. if so, re-sync.
SOURCE: My SGX screen is frozen with the first hole of my
remove the battery and reset the system.....should be ok.
SOURCE: i have just bought a
Hello.
If you have the update installed, your Sky Caddie Legend willdisplay the information on startup. You can also change the owner information.You may want to change the information if you purchased the GPS used, ornoticed an error in the information.TOLLS NEEDED AND INSTRUCTIONS ARE STATEDBELOW.Software update 2.42 or higher1 Press the "Thumb Stick" to display the Sky Caddiemain menu.2 Scroll down with the thumb stick and select"Options." Tap the thumb stick to enter the menu.3 Select "Owner Information," and tap thethumb stick to enter the folder.4 Enter or change the current owner data (Name,telephone, etc.). Scroll down with the thumb stick and select "OK."Thanks.
