I have a eMachine that will not complete POST test, freezes when it identify the hdd, CD and DVD drives, neither will it allow me to enter the BIOS setup, can you help?
SOURCE: Emachines T3882 desktop w/one cd-dvd combo drive[no floppy]
Download the drive test for the hard drive. Put the drive in your other computer and run the test. If it test good on simple test do the long test. IF IT COMES OUT FINE, Run the Zero program and then try to install the O.S. Check your BIOS settings and make sure everything is set right. You are on the right track. You just did not know how to test the drive. If it is a Toshiba you will not find a hard drive test. You might be able to use the Maxtor or Seagate drive test. Use the windows version if you can. If you can't do any of the test, right click on the drive and check for errors.
Rate me if this helped.
SOURCE: emachine boots to bios with a new hard drive installed
well your jumper is probably set to boot right to bios. you have to go into your comp and move the jumper to its origional location.
SOURCE: Don't know how to reformat my emachine T5010 desktop PC
Reformatting your Windows computer is usually the absolute last resort and is often done unnecessarily. Before you go through the process of doing a reformat of your hard drive please take a few moments to read through the rest of our website. If you are reformatting to fix problems with your Windows computer it's possible that by using some of the tips on our site, or by downloading or purchasing some of the tools or products that we link to, you might be able to avoid the need to reformat your computer. Because doing a complete reformat of your computer will erase the contents of the hard drive and require you to reinstall all software, reformatting is usually a last resort.
Some Computer Manufacturers Make Reformatting EasyMany name-brand PC manufacturers include a restore-disk which makes it easy to reformat your PC and return it to the state it was in on the day you purchased it. Some manufactures supply only a standard Microsoft Windows CD, and some (usually lower-end PC manufacturers) supply neither! If your PC did not come with a restore or reformatting CD, then you will need to take extra steps to format your hard drive and get Windows re-installed.
Back Up Your Files Before You Reformat Your Windows PC!Because the reformat or restore process erases everything on your computer, it is critical to have a backup of any important files on your computer. You will also need your original software install disks to reinstall any software you have purchased.
Things to do before you reformat your PC hard drive
SOURCE: BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
SOURCE: Blue Screen c000021a
boot system into safe mode. locate the icon for my computer. right click and go to properties. locate the computer name tab and select it. find the radio button for "change" and click it. rename the computer to something considerably shorter then what you have. the system cannot boot and complete the logon process if the computer name is longer than 200 "bytes"
