Compex (sxp2224wm) Networking Switch Logo
Arjun Adhikari Posted on Jun 17, 2007
Problem with SXP2224WM compex switch.
I have just completed cabling for 35+ computers. When i connect the SXP2224WM compex switch, computers show network is connected. but no ping works. bytes sent and recieved is very less. what may be the problem. when i test the cable with cable tester, it shows fine. More interestingly, When i connect hub replacing hub, it works fine and there is full connectivity. what may be the problem. thanks.
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Jun 18, 2007
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
15862
Points
55
If I remember correctly, this device has vlan. Did you check to make sure that the vlan is configured or turned off? And does this have a firewall? Seems like a firewall is blocking ping port but allowing traffic. Also, I thought the 24WM was a 24 port switch, you mentioned a hub, but what kind of hub is it? It really sounds like a port blocking issue.
Only shows power led,ports are not working.
Is it a new item? or used? Did it at any point work with your computer? Also, make sure the main internet connection is going into one port, and another cable is connected to the pc, and that a light is active at each connection point.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_005777b2fc6bfc30
Acc current showing on rj45 cable when cnnected t this device
Can you ask again explaining what you mean by 'acc current' ? This machine doesn't have anything to display that.
Have you installed it correctly ? The Install guide is here.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000010579.pdf
HOW DO I RESET Compex SXP2224WM-110 TO DEFAULT CONFIGURATIONS
To restore factory default settings, press and hold the reset button for 8 seconds and release! When you are holding the button, pls pay attention to the LED lights, at the beginning one of the lights will be on stably and then it turns to blink faster and faster. Suddenly,it stops and become slower, at this moment you can release the button and later all the lights will be on, it means the device is rebooting. When the device is completely started,you can check it.
2answers
What is the output specification of the hub T1008c network hub
8 port 10 Base-T (10 Mbps) with a BNC for Coax cable connection.
Hello. I have switch, model PS2208B. may be it was
A cheap little switch like that is a throwaway. Buy a new one it is toast.
How to play game through this?
Both computers must join the same workgroup:
System > Computer name > Change... > Workgroup : "MYWORKGROUP" > OK
How to default the switch
turn off your swith and reset all things
1helpful
Can connect ps2208b to my desktop pc
sir
cable length is 100 meters long. how can i connect?
Top Compex Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Compex Computer and Internet Expert? Answer questions, earn points and help others
