"Please insert Disk 1" prompts after evert boot. I know its' a registry fix but I don't know how?
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. also download the registry cleaned cc cleaner
http://download.cnet.com/ccleaner/
You can also run a free registry scan using utilities from http://re7.info http://www.download3000.com/showarticles-182-0-date.html System Utilities. http://www.download3000.com/showarticles-178-0-date.html Optimisers and Diagnostics. Hope this helps.
SOURCE: Recovery disk needed
reboot
on reboot, enter BIOS setup, F1 Esc, whatever the prompts say
and change the boot sequence to a valid drive.
This may not work since you did not say what occurred to __kup the boot sequence
SOURCE: can not reboot
Try tapping F8 at start up and try booting in safe mode...If this fails you will need to reinstall your OS.
SOURCE: I ran Sony recovery CD in Dell laptop
im afraid the only way i can think of is get you hands on a dell reinstallation cd and use it. it will mean eraesing your harddrive though
SOURCE: compaq sr1750nx presario recovery
go to the compaq sight and download the drivers and software from them, burn to a disk and then run it
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
which operating system ?
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased.
Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
hope this helps
To run the check disk utility you will need a repair disc or
a operating system disc. Put the disc in the cd drive and boot from
it. You want to get to the Dos Command Prompt (Black screen with white
letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
