I am new and tried to get the game working but I do not know what button to push to make clutch and breaks to work or which button to press when I want to adjust all the different adjustments that we can do. I am using playstation 3 and the game I had was Nascar 08 but when the showed the tutorial the set up everything nobody told me which button is which PLEASE HELP .. where do I look or read so I do not mess the steering wheel and clutch and gear shifter up Thanks for the help 50 year old father
The button can be an important part of a project. for example, the momentary button output logic HIHG when pressed and logic Low when released. The panel mount design makes it really suitable for installing on actual projects.
Elecrow Crowtail Button can be colorful, There are five colors of the button including black,red,blue,green and yellow. It can help you control the other modules.
Buttons for the G25 wheel and PS3
Top 4 The Black ones
Top-triangle-cancel-reverse(gear to back car up)
Left-square-cancel
Right-circle-E_brake
Bottom-X-enter You can also use the gas pedal for enter
Bottom 4 buttons The Red ones
Far left-no function
Second button-Change view
Third button-Pause-quick exit replay at the end of race-This button will also speed up the winnings (to keep from waiting with the cup spinning around so you can get back to racing)
Fourth button-best race line for license test
Buttons on wheel
Left-look back (default)
Right-nitro (default)
I change these two buttons around myself so I have the nitro on the left.
D-pad-same as the controller up,down,left,right. For menue use.
Also for (during race)
Look back-bottom pad
Look left-left pad
Look right-right pad
To change any of the button functions use the DFP settings in the options menue.
I have not used the wheel in photo mode. The only thing you can't do with the wheel is "exit" game. I also never have my controller on during gameplay I only turn it on to exit the game. If anyone needs anymore help with this wheel give me a shout-back and I'll try my best to help.
One last thing make sure your wheel is in the far left port(port 1) or port 3
