Toastmaster 200 Waffle Maker Logo
A
Anonymous Posted on Dec 07, 2012
Need 2 prong cord for old waffle maker
Don't know waffle maker number. It was bought in the 1970's.
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on May 01, 2015
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
500671
Points
3432
Visit your local thrift shops in search for a replacement
Douglas Jensen
Level 3:
  • Toastmaster Master 494 Answers
Douglas Jensen
Toastmaster Master
Level 3:
Answers
494
Questions
0
Helped
205812
Points
1354
The model # is stamped on the bottom side of the unit, or on bottom where the cord plugs into it. Once you have the model #, you can find a good used replacement cord on eBay.
1 Related Answer
kebah
Angel Joseph Jr.
  • 685 Answers
  • Posted on May 18, 2011
SOURCE: toastmaster personal waffle maker--Model TMWB4BELW
Try to visit www.middleby.com and go to toastmaster and locate the nearest sales office to your area.
1helpful
I am looking for the power cord for a Toastess waffle maker model -571. Can I purchase one through here?
We are not sellers on this site, but we do help people with specific problems and sometimes even help locate parts they need. I looked up your make/model and it appears the cord is a very common one. Here in the U.S. it is readily available at our local hardware stores. It can also be found on eBay, but you need to know the center to center prong measurement on your waffle iron to order the correct cord. Good luck!
No power to the air pump
Power board is defective and needs replacing
The plastic bottom to the waffle maker melted. I have only had it for a year or so. I don't know when or how it melted. Where do I get a replacement bottom for the waffle maker?
You can write down the brand and model # of the appliance then go on-line and search " your brand, model # and replacement parts. You may have to change up the wording a couple times to get to a site you want. Once you have found the model number and part you need you can usually order it on-line and have it shipped to your home.
2helpful
I lost the instructions for my sunbeam waffle maker, and I dont know how long Ihave to bake it.
Here is a direct link to the User's Manual for your appliance:
http://dl.owneriq.net/d/db0acd4e-57c1-43f0-a51b-4ef04ad30e2d.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Joe.
I open a Kitchen Gourmet Waffle Maker Model #SW-035A The unit plastic cover is broken. The box was not crushed. Where do I exchange the unit for a new one. Thanks for your help in advance James...
i would take it back to the place you bought it at and have them replace it if not there should be a phone number on your instruction manual that you can call for customer service.
5helpful
2answers
My waffle maker has the light on but it is not getting hot enough to make waffle. Is this a fuse problem? HELP!!!
Most likely, the thermal fuse inside the lower half of the unit is blown. It is a 240 degree celcius fuse found inside a white insulating sleeve. A replacement can be found here on Amazon.com.
1helpful
Need new electric cord(2 prongs) for coffee maker
I was pleased to find West Bend still around and carrying what one needs to avoid adding to the land fill:
2-Prong Cord
Top Toastmaster Kitchen Appliances - Others Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
