Gas tank is spewing gas out when test is being done. idle is too high 950 to 1050. i changed plugs, cap, rotor, wires replaced steering column, removed spark control module and it ran the same without it. is reg in tank bad or is my engine the problem. how do i accurately adjust the valves and which is int., and which are exh on my 1985 pontiac firebird 305 tpi and firing order and location of each cyclinder?
SOURCE: I have a 1992 Pontiac
do a vacuum test on the FPR if it IS holding vacuum, then i would try to test the fuel pump.
