Instructions on setting the alarm
SOURCE: How to set time/alarm GE Auto Clock Set Radio Model 7-4892A
I have a solution for the GE Auto set clock and radio model number 7-4892A. The only way that I had found out just by accident is that you are suppose to hold down the manual clock set until you start to see the Year and then the Date. There you will be able to set it to the correct date or year.
Idea from
Guest
SOURCE: Instruction Manual for Timex Alarm Clock Radio T309T
Here is a website for the manual:
http://www.timexaudio.com/product_manuals.asp
You have to find the product number, located on the bottom. EX: T-309
SOURCE: alarm clock came with chinese instructions manual,I need English
1.slide "return to time"to off, slide "backlight" to on
2.each press of the mode button goes through "time, temperature, year, month(M looks like an H) and day(D), alarm1, "2, "3, , Birthday Celebration, countdown/stopwatch"
3. when on the category u want to change, press and hold set button for 3 secs, adjust with up and down and the hit set when done with each adjustment
Buttons on the bottom in order from left to right are(buttons on the top part of the clock bottom when turned on its side) mode, set, up, down
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
SOURCE: GE 7-4894A Need instructions on how to set the alarm.
The manual is at http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
