You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
It is not automatic that phone will vibrate when you receive a message. You have to set the phone. For that you go to settings in the Menu and then select phone settings. Go to Message Alert and select Vibrate and Ring option. Click OK/Save depending the display on the screen
To turn on a ringtone and vibration, go to your BlackBerry's sounds and ring tone options by either of the following ways:
1. Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
2. In the Home folder, go to your Options folder (usually toward the bottom, has a wrench icon) and select Sounds and Ring Tones.
Select the ring tone and volume that you want, and for Play Sound select Always. Scroll down to Vibration and set it for On.
There is an option for Vibrate with Ring Tone -- set that to on in order to make your phone both ring and vibrate at the same time, then save the settings when you cancel out, and you're all set.
The Sound Profile only covers call sounds. Sound Profiles This menu allows you to specify how you are informed of incoming calls. Selecting a Profile 1. Touch ➔ Settings ➔ Sound Profile. 2. Touch the radio button next to the profile name. The selected profile activates. Choices include: • Normal • Silent • Driving • Outdoor Normal Profile The phone’s profile defaults to Normal. Use the following procedures to change the profile. Editing the Normal - Call Profile 1. Touch ➔ Settings ➔ Sound Profile ➔ Normal. • Touch the name field and not the radio button to the right. 2. Touch drop-down menu (upper-right of the screen) and select Call. 3. Select the Call Alert Type field and select one of the following and touch Save: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration then Melody: the phone vibrates and then starts ringing. • Vibration & Melody: the phone vibrates and plays a melody simultaneously. 4. Touch the Voice Call Ringtone field, touch to select a ringtone and touch Save. 5. Drag the Ringtone Volume slider to the volume level you desire (range is 1-7). 6. Touch the Vibration Pattern field, then touch to select Vibration 1 - 5. 7. Touch Save to return to the Sound Profiles menu. There is no mention of keyboard tones in the user manual.
