SOURCE: I have a set Motorola
You need to user an Override Plug, which can be fabricated this way:
To fabricate an override plug:
1. Install an RJ-11 6-pin connector onto a 6-inch length of CAT 5 cable.
2. Pin out all 6-pins.
3. Short (solder together) Pins 4 and 6 on the other end. Do not connect any other wires to
anything. The result should be as follows:
Pin 1 ? white / orange ? Pin 1
Pin 2 ? white / green ? Pin 2
Pin 3 ? white / blue ? Pin 3
Pin 4 ? green ? Pin 6
Pin 5 ? blue ? Pin 5
Regaining access to the module
To use the override plug
1. Insert the override plug into the RJ-11 GPS sync port of the AP.
2. Apply power to the module through the Ethernet cable.
RESULT: The module reboots with the default IP address of 169.254.1.1,
password fields blank, and all other configuration values as previously set.
3. Set passwords as desired.
4. Change configuration values if desired.
5. Save the settings.
6. Remove the override plug.
7. Power cycle the module.
You can view more details at:
http://www.canopy-wireless-solutions.com/AppicationNotes/APManualIss5.pdf
