SOURCE: cant copy the numbers from my phone to my new sim card
this problem is due the sim space may be u have 32k or16 k sim . so memory is nt enough to save all the contacts - so do these things to solve ur problem .. 1) if u have an alternative sim which is 64 k sim then copy all the contacts in that sim then transfer them to ur required phone afterwards ... 2) if u any other alternate phone than transfer half the contacts in first atempt than transfer rest the contacts in other atempt...
SOURCE: Sony Ericsson Z525A-COPY PHONE NUMBERS TO SIM CARD -BLANK SCREEN
to retrieve your numbers you would need to follow these key strokes...
center, toggle down (1 time), center, toggle up (2 times), center, toggle down (5 times), center, toggle down (5 times), center (3 times)
then wait for quite some time...it takes a while to copy all of the contacts...I would say anywhere from 5 to 10 mins...
this should work to save your contacts.
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable for the z525a. I haven't tried this but it should work since that is what the cable is for.
Its called a DCU-60 USB data cable, and is listed as being compatible with the z525a.
SOURCE: unlock prepaid pantech c120 to use SIM card from contract phone
That sounds like a feature to me. I suggest you use that to your advantage and put in some prank calls.
SOURCE: Sim card rejected
you can't switch SIM cards from a tracfone to any other phone. you can't even swith SIM cards from one tracfone to another.
