my computer will not recognize the pictures either. it says there are no pictures on the cameramy computer will not recognize the pictures either. it says there are no pictures on the camera
I have the very same problem. It is irritating. I cannot get the desktop to read the camera card.I have the very same problem. It is irritating. I cannot get the desktop to read the camera card.
AnonymousFeb 21, 2009
sorry, i wish i could help but i too have the same issue it says ther is no connection and that i need to press the button on my dock I HAVE NO DOCK!!!sorry, i wish i could help but i too have the same issue it says ther is no connection and that i need to press the button on my dock I HAVE NO DOCK!!!
You can't post conmments that contain an email address.
Re: Kodak m1063 do I need a camera dock to download...
Try a smaller memory card. I had an 8 gig card in the camera and the pc would not recognize it. I switched to a 1 gig and it found it right away. The problem is in the pc not the camera.
No. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Scrap the camera! Kodak hasn't and won't address the problem. Most picture download software won't recognize the camera. The only solution is to remove the memory card from the camera, put it in USB adapter and treat it like a flash drive. Cumbersome. Awkward. Stupid. After you scrap the ****, tell your friends so they don't make the mistake of buying a Kodak.
Sounds like a cable fault.
Try w. a different cable.
Remove the battery Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt. If you do not have access to a dif. battery. Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Go to Staples or Tiger Direct or Canadian Tire, or some dollar stores cary it too, Radio Shack , the Source etc.
Ask for reg -USB to mini USB, bring camera there so you can test it. You can get a 5 volt charger as well for about 12.00.
Vitally
