Do i need to replace the throttle body to to replace throttle position sensor
SOURCE: 2008 Honda Civic si
Go to any auto parts store and you can use the meter to see what code it comes up with, The meter has the codes on it and will tell you why the check engine light is coming on.
SOURCE: replacing bad camshaft position sensor
Reverse procedure to install and prior to installing new sensor, lubricate sensor O-ring.
It is located under the water pump. Make sure when you remove the sensor that you rotate the crank shaft and look in the hole to make sure the pick up magnet is still in there. Sometimes they come loose and cause a no start or long crank. You will need to have the code cleared still.
SOURCE: I am needing to replace the throttle position sensor
It is located in the large hose coming from the air filter it just pulls out
SOURCE: Missing, stalling Pontiac Sunfire
The OBD II code for P0400 is Exhaust Gas Recirculation Flow Malfunction.
I'm sure the only thing you have left is you may have to replace the EGR valve or check for any leak from the vaccum lines going to to EGR valve.
SOURCE: on a 04 camry with 2.4 ltr engine, can I replace
I think the terms "Throttle Positon Sensor", TPS and "Throttle Body" can be misleading at least in regards to the 04 Camry.
My 04 Camry gave a diagnostic reading of P2121 for my problem "Throttle PEDAL position switch D circuit". However, we changed out the complete Throttle Body/TPS (Toyota Part #22030-0H020) that did NOT fix problem.
The 04 Camry TPS Electronic Module "Throttle Positon Sensor" is factory assembled and riveted to the side of the throttle body. The only way to service/inspect it would be to cut off or drill out the rivets. Not sure you could open the darn thing if you got it off, but that seems to be the only way Toyota sells them!!
Hopefully a new Throttle PEDAL Position Sensor (Toyota Part # 78010-33010 PEDAL ASSY, ACC)
will fix it. This is located under the dash near the accelerator pedal.
So, now I would recommend FIRST to replace the "Throttle PEDAL Positon Sensor" (it is much, much cheaper) and then the Throttle Body/TPS assembly!! Unless of course, you get a diagnostic code as you did for "faulty throttle body!!
