Sizzix EClips - Electronic Shape Cutting Machine and Handheld Remote Control Starter Kit Logo
John D. Olmsted Posted on Oct 23, 2012
Repair sizzix eclips
Will not cut
Kim Stryker Cronkright
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 18, 2014
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
584
Points
My sizzex eclips won't turn on, help
I NEED A REPLACEMENT SCREW FOR MY SIZZIX BIG SHOT HANDLE.CAN YOU HELP
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
1helpful
I have bought a sizzix eclips ec-1200 electronic cutting machine serial number b 051878,where can I get an authorisation code from,thanks
Hi Patricia!
You may try to get in contact with Sizzix and explain them that you got a second hand machine and you need the authorization code and software to put it to work. I guess they will be glad to help you.
Sizzix support page can be reached at the link below:
Support
Hope you may find this answer helpful!
Best regards,
Miguel L. Martitns
My sizzix eclips won't turn on
Sizzix Eclips help please - Make The Cut! Forum
forum.make-the-cut.com/discussion/25227/sizzix-eclips-help-please
Jun 10, 2012 - 9 posts - ‎6 authors
I did email Sizzix but they won't answer until during regular business ... If you turnedoff the cutter, then start again, it should work properly. Turning off the grid lines and plus signs on the mat.
Nov 18, 2013
htv question
Sep 16, 2012
Plug In for the Sizzix Eclips, please!
Oct 8, 2011
roland blades
Jun 10, 2011
More results from forum.make-the-cut.com
[PDF]Help - Sure Cuts A Lot
Nov 14, 2015 • Saws
1helpful
Machine jammed
you must contact to the supplier manufacturer in order to get support via ONLINE chat.
GOD BLESS YOU
My Sizzix Eclips stops cutting half way through and sometimes ejects the paper at this point. Is there a fix for it?
I am having the same problem:I changed the blade, but before this it was turning off as it begins to cut. My machine is just 2 month old.
maria Lucia
Power antenna does not go up and down automatically. Makes noise when car is cranked and cut off
i just replaced the cd player in my 2001 eclips spyder and the power antenna now wont go up or down but it works with the old cd player what can i do to fix the problem please?
1helpful
Cannot use die cuts
No I don't think your machine is defective. Here are some "sandwich" ideas to help you. I know you asked just for Cuttlebug dies; I included other "sandwiches" that you can do with your Cuttlebug. If you need further assistance feel free to contact me.
Cardstock
Chipboard
Magnetic/ Metal Sheets & Thin cork (Media)
Cuttlebug Dies
Plate “A”, Plate “B”, Die (cutting side up), Cardstock, Plate “B”
Plate “A”, Plate “B”, Die (cutting side up), Chipboard, Plate “B”
Plate “A”, Plate “B”, die (cutting side up), Media, Plate “B”
Cuttlebug Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”
Plate “A”, Plate “B”, Folder (with chipboard inside), Plate “B”
Plate “A”, Plate “B”, Folder (with metal sheet inside), Plate “B”
Nestabilities
You will need Spellbinders Tan Embossing Mat to emboss in
Cuttlebug™ machine (or a plumbers gasket cut to size, or some use a mouse pad)
Cutting Sandwich - (Stack from bottom up)
1. A plate
2. C plate
3. Spellbinders Die (cutting side up) that means the side with the
ridges
4. paper or cardstock
5. B plate
6. Run through Cuttlebug™ machine.
Embossing Sandwich- (Stack from bottom up)
*Remove C Plate for embossing sandwich
1. Place A plate on bottom
2. Leave die face up on A plate with die cut still in the die.
3. Place one Spellbinders Tan Embossing Mat on top of the die.
4. Use 2 or 3 pieces of cardstock to shim.
*Cautionary Note: Using more than 3 pieces of cardstock to
shim Cuttlebug Embossing sandwich will result in B Plate
breakage. When using Spellbinders Edgeabilities card making
dies, shim with only 2 pieces of card stock.
5. Place two acrylic B plates on top of sandwich and run thru
Cuttlebug machine to emboss Spellbinders die cuts.
6. Turn die over and use like a stencil with inks and chalks for
added detail.
BigShot Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”, Cardstock shim
BigShot Large Dies
Plate “B”, Cardstock, Die (cutting side down), Plate “B”
Revolution Dies
Plate “A”, Plate “C”, Die, Cardstock, Plate “B”
Sizzlit Dies
Note: Provocraft suggests using Plate” C” instead of the second Plate “B”, however, CB owners have cracked plates, so try with two “B” plates first.
Sizzix Original Dies & other Steel Rule Dies
Plate “B”, Chipboard, Die (cutting side down), Plate “B”
Sizzix CutNFold Dies
Plate “A”, Die, Cardstock, Plate “B”, Chipboard shim
Also try:
Plate “B”, Cardstock, Die, Chipboard shim (maybe 6 layers)
Sizzix Embossing Folders aka Simple Impressions
Also try:
Plate “A”, Chipboard shims, Folder (with cardstock inside), Plate “B”
QuicKuts Dies (Regular)
Plate “A”, Plate “B”, Die, Cardstock, Plate “C”
Plate “A”, Plate “C”, Die (cutting side up), Chipboard, Cardstock shim, Plate “B”
QuicKuts Dies (Grand)
Brass Embossing Stencils
Plate “A”, Plate “B”, , Brass stencil ,paper/cardstock,mouse pad (cut to size, rubber side down), Plate “B”
Sandwich may need to pass through several times based on cardstock thickness
Or use plumber’s black rubber plus red rubber gasket, instead of mouse, then add last plate B.
Big Impressions Texture Plates
Plate “A”, BI texture Plate, Cardstock, Silicone Rubber pad (from BISK), Impressions Pad (from BISK)
*BISK-Big Impressions Starter Kit
Fiskars Texture Plates
Plate “A”, Fiskars texture Plate, Cardstock, tan Wizard pad, black or tan Wizard pad, (possible Cardstock shim,) Plate “B”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (lightly misted with water), 2 layers Fun Foam, Chipboard Shim, Plate “C”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (right side towards TP), Rubber Plate (made from Plumber’s rubber gasket), Plate “C”
Plastic thin stencils
Here too- may try
Plate “A”, Plate “B”, , plastic stencil, cardstock, black rubber, red rubber, plate B
It cut off while driving
my eclipes use to stall out when slowing down to make a left or right turn or stoping for red lighr or stop sign now car sounds like it wants to start but will not can any body help
Top Sizzix Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sizzix Televison and Video Expert? Answer questions, earn points and help others
