That file (6aja4r4.exe) is a self-extracting compressed file, about 5.6MB in size. I downloaded it to my system, then scanned it with both the Avira Anti-Virus and Malwarebyte's Anti-Malware programs, which found no problems. I then double-clicked the file (6aja4r4.exe) and it extracted 11 .PDF files; those files are the Table of Contents (6aja4r4-table.pdf), the four main Chapters (6aja4r4-1.pdf through 6aja4r4-4.pdf), and the six Appendices (6aja4r4-a1.pdf through 6aja4r4-a6.pdf).
Let's do this step-by-step:
1. Open Windows Explorer and create a new folder somewhere on your hard drive where it will be easy to find; I named the new folder "Chaintech_CT-6AJA6r4_motherboard_manual".
2. Download that file (http://www.motherboards.org/files/manuals/19/6aja4r4.exe) into the new "Chaintech" folder.
3. When the download is completed, scan the file with your AV and anti-malware programs to be sure that it is clean and won't cause problems on your system.
4. When you know the file is safe to open, double-click the file (6aja4r4.exe) and it will extract the 11 .PDF files I mentioned into the "Chaintech" folder.
5. Double-click the file named "6aja4r4-table.pdf", which is the Table of Contents for the manual. The ToC will tell you what information is contained in each of the other 10 files. Chapter 1 (6aja4r4-1.pdf) is titled "Introduction", Chapter 2 (6aja4r4-2.pdf) is titled "Hardware Setup", Chapter 3 (6aja4r4-3.pdf) is titled "Award BIOS Setup Program", and so on.
Good luck with this; hope this information helps you. Let me know if you have any questions about this Chaintech motherboard; now that I have the manual on my system, I can probably help you to find any specific information you need about this Chaintech motherboard.
Hi, check the cable from your computer tto monitor, then check that the video card is installed properly.
If these fail your video card is most likely dead and need to be replaced.
Regards mistyman
The connections are show between the last 2 PCI slots. The connector is CN1A.
Here are the connections.
1 & 2 = G Button
3 & 4 = HDD Led + to pin 3
3 & 9 = Power Led + to pin 9
6 & 12 = Speaker + to pin 12
11 & 13 = Power switch
14 & 16 Reset switch
17 & 18 = G Led + to pin 18
15 is keyway [no pin]
Chaintech MPM800-3 Motherboard
