Master
- Posted on Oct 16, 2012
Re: commercial bunn brewer is making loud buzzing sound
See the next steps and fix it yourself. God bless you
- Unplug the unit from the electrical receptacle.
- Remove the pot and basket. Remove or tape closed the water reservoir lid.
- Turn the appliance over and remove all screws that secure the case
halves. Lift off the case to expose the heating element and controls.
- Inspect the control cavity to determine if the solution is simple:
disconnected wire, debris, etc. If so, fix, reassemble, and test.
Otherwise, continue with the next step.
- Use a DVOM to test the heating elements and the switch, thermostat, and timer
- Replace any defective parts or decide to replace the appliance, as appropriate.
- Reassemble the appliance and reinstall the pot and basket.
- Fill the water reservoir approximately half full, then plug in and turn on the coffee maker to test its operation.
