SOURCE: 1999 dodge ram 1500 haveing problems
hi the fuse you will be looking for will be a 15 amp fuse as the loading is low on light curcuits i don't
know which fuse no as they fitted 4 different fuse boxes on the rams but you should start by checking the 15 amp fuses with a multimeter for continuety or some time hold a torch close to the fuses and you will see the link broken
SOURCE: 2003 Denali Yukon, no Brake lights, no Cruise Control, fuse is OK
Check your brake light switch at the pedal. This controls the lights and disengages the cruise when stopping. I'd look there before I go anywhere else. There may just be a wire loose. Could be a simple fix.
Good Luck and hope this helps.
SOURCE: dodge ram 1500 the radio and dash lights are not working
did u look at the fuses under the hood there might be one there other than that sounds like you wiring went bad or the part of your switch is bad replace the switch
SOURCE: airbag light, no horn or cruise control
You need to install a new colckspring. Go to dealer parts department and ask them to show you the diagram. You have to pull the steering wheel. Be sute to disconnect the battery because you could deploy your airbag. Good Luck!
