Nokia 5210 does not stop switching on and of flattens battery in 30 mins old phone but basic and reliable
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
SOURCE: my phone nokia 5210 has switchoff when i start
To do that you must install Nokia PC Suite to your PC. Must have a USB cable to connect the phone to the PC. Charge the battery fully. Backup your data including the contacts and msgs etc. Connect to the PC after running PC Suite. In that you find an icon for updating. When clicked, it will down load Nokia Software Updater. Run NSU and then follow the instructions. Your phone will reboot once. When it comes on, it will be new phone. And if it does not due to a glitch in the internet connection, then you will have to throw it away as even Nokia will not be able to repair it. It has happened to my Nokia E61i.
The alternative is to get it done from Nokia Care who download the complete SW before commencing the update. Thus the whole firmware is rewritten and the viruses etc get removed automatically. Not so when you do it yourself.
SO, even if you have to pay a little to Nokia Care, it is worth the trouble.
SOURCE: Unlock 5210 nokia phone from at&t?serial number is 353226010982993
hi you can use codes to unlock your nokia 5210 .you can get the codes from this site unlock-free here they render the codes to unlock at free of cost along with the instructions about how to use the codes in your mobile.
hi you can use codes to unlock your nokia 5210 from at&t network .you can get the codes from this site unlock-free here they render you the codes at free of cost.
