The headligts stay on although the switch is in the off position, and no ignition key in . Draing the battery and causing the lighting relay to buzz.
SOURCE: my ignition switch is stuck on my lexus es300
It sounds like you need to replace the ignition switch. This happened to me about a year ago on my 1999 ES 300. Usually part of the ignition is stripped or broken so the key can't move. It's a pretty easy fix, you have to take off the plastic dash cover so you can unscrew the ignition switch and slide it out. The problem you'll have is when you put in a new ignition you'll get new keys with it. The ignition key will be different than the locks on your car. I have to carry two keys now, kind of a pain, but cheaper than having your locks rekeyed.
SOURCE: LEXUS es300 oil light stays on oil level full
Check oil level sensor, replace if necessary. also, does your engine knock or make a tapping sound?
