All the lights are blinking except the auto-off, and there's no noise, no nothing
SOURCE: my keurig coffee maker turns its self off, even
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
SOURCE: lead in the coffee maker
It does contain a small amount of lead inside a copper coil located in the electronics of the machine. This part does not come in contact with the water, heater or any other part that would cause lead contamination of your coffee.
This page has a great write up explaining it:
http://coffeebreak.today.com/2009/04/08/keurig-lead-warning/
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
SOURCE: The Water Reservoir is leaking on my keurig coffee maker.
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
SOURCE: when i put the coffee cup in the keurig....nothing
use a small needle, paper clip or pipe cleaner and run it up into the "needle" section under the lid that pierces the top of the cup. The problem is one you will have often as coffee grounds get up in there and dry between uses and clogs the hole.
Mine too, what's the deal?
