The battery has been replaced and the alternator is not putting out quite the correct voltage but isn't really bad yet I don't think. It's will start ok for 4 or 5 days and then it won't but. Test battery and full charge but will not turn over. Lights and radio whatever come on but will not even try to turn over. put jumpers on it and starts no prob. Help.
SOURCE: 2000 Mazda MPV-DX 2.5L V6 won't turn over just clicks.
yes it could be the starter next time it won't start give the starter motor a tap with a hammer or wheel brace also check where the small blade connector is there should be a fuse in line could be the problem hope this helps regards Jim
SOURCE: 2002 MAZDA TRIBUTE ALTERNATOR PROBLEM.
You might want to follow the wire(s) that go into your alternator are properly connected. If you have a bad connection on either side it will cause it to cut in and out and fry the coils in it.
SOURCE: I own a Mazda 2003 Tribute LX V6 3.0L. The other
check your engine and battery ground wires and the fuze links.
SOURCE: Battery dosn't charge, alternator/voltage adapter test's good.
Did you test the Alternator on or off the truck? It might be a problem with the control system to the Alternator. The regulator need a battery feed to work, It is usually ran through an alternator fuse.
SOURCE: electrical issues (2 or 3) with Mazda Tribute 2002
hello there, there is a way to check if the alternator works, just start the engine and run it at idle for a minute or so just to get the engine warmed up. while the engine is running, try to remove the positive terminal cable from the battery (note: no lights, radio, or any accessories operating). the alternator should be sufficiently providing power to the engine. if it dies down the charging might be weak. another way is purchase a digital multimeter and setting it to dc voltage testing. put the tester prongs on the correct terminal( positive to red positive and negative to black negative) test the voltage prior to starting. usually it shall read 12. 3 or a tad higher. remove the tester prongs from the battery terminal and start the engine. then place it back on. the reading shall read 14V plus without any load. sometimes it might read 15V w/c is usually over for certain cars. then turn on all accessories: headlights, aircondition/heater and etc. if the reading on the tester indicates 12.8V and above 13V your charging system is ok.(all this test is on engine idle)
For the battery, my experience is that 2 years of battery duty is quite good already. unfortunately, during these span of duty the battery might give a 12V reading but its strength is not enough to sustain the load. the voltage of the battery is the physical attribute so to speak and ampere is the power or strength of the battery.
for your accessories that died, I think something tripped when you jump started it. but the accessories are easily traceble. I think what's important is keeping the engine in tip top condition and won't let you down during hard times.
hope some of this helps you.
