Samsung UA46EH5000 46-INCH MULTISYSTEM LED TV FOR 110-240 VOLTS Logo
Posted on Sep 07, 2012
I want to know the picture setting of UA46EH5000 LED SAMSUNG TV
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
LG LED LCD TV-I had no sound and a black screen, replaced the main board, still the same
IT is not wise to attempt repairs on LED TVs. They rarely work, and you end up replacing the unit anyway. The newer units have the LED drivers connected directly to the LED screen and there is no way to repair/replace them. Board swap/replacement is tempting, but overall the lost time versus the cost is often not worth it. Sets today are only designed to last 3-5 years. The manufacturers use the minimum rated electronic parts to ensure failure and thus a steady stream of replacement buyers. Some don't even make it out of warranty, but the manufacturers are willing to risk the cost in order to ensure that the planned obsolescence continues. Gone are the days of a set lasting 10-12 years or more. Take that into consideration when buying a replacement and only get what you need. Buying newer features that are not in full use yet only costs more and by the time you get the benefit of them, its time for another new set.
Samsung55in led tv. 7100 series. After a few minutes of being on the picture goes off. But the Samsung power indicator light remains on.
No doubt. Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
How do I turn off the starting sound on a Samsung series 7 tv?
On your Samsung remote. Press the MENU button. At the botttom of your screen you have the setup selections. Scroll over to the SOUND option and select that, A menu should appear and toward the bottom of the menu you should see MELODY. Scroll down to that and select ON or OFF...
TV has recently began displaying 2 images slightly offset from each other with lines. I absolutely love this tv plz help!
you have a digital problem..ive narrowed it down to 2 boards..the Main Bd..and the Tcon board..here are the purchasing details
http://www.shopjimmy.com/samsung-bn95-00496b-t-con-board.htm
http://www.shopjimmy.com/samsung-bn94-05038b-main-board-for-un40d6000sfxza.htm
looks like the main board is on backorder..id replace that first..its most suspect..lemme know how it goes
Samsung 55" turns ON/OFF by itself and will not connect to wifi network
I have the same issue. I read and watched online tutorials about the compositors but after opening the set up I was unable to find any that had gone bad. I was able to upgrade the software by using a USB thumb drive but the issues are still there. I'm thinking of swapping out the motherboard and/or the power board next to see what the fix is.
Top Samsung Watches Experts
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Watch Expert? Answer questions, earn points and help others
