do u have premium sound with a separate amplifier, I need to know this to diagnose the problem properly.do u have premium sound with a separate amplifier, I need to know this to diagnose the problem properly.
You can't post conmments that contain an email address.
If the 4WD service light comes on when you start your Hummer H2, it could indicate a problem with the four-wheel drive system. This warning light could indicate a problem with the transfer case, the drive shaft, the front or rear differential, or other components of the 4WD system.
It is recommended to take your vehicle to a certified mechanic or a Hummer dealership for proper diagnosis and repair. The service light coming on could be a sign of a serious problem, and it is important to address it promptly to avoid further damage to your vehicle and ensure safe operation.
Here is what I show from the manual. 2005 Hummer H2 Car Audio Installation Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Gray
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Under the Center Console or Behind the Glove Box
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
It could be a bad amp. Those come with a factory amp usally right behind the radio. Hopefully you can find a used one from a scrap yard. Click Here to search in your area.
i know gms have a light sentinal in the dash. when it says it's dark out, it will automaticaly turn your lights on. dose your hummer have one? if so, try cleaning it off.
I have no idea about amplifiers. I just usually turn on the radio and there is sound. Everything looks fine the lights come on but just no sound
