The left turn signal is intermittant, but the right one works just fine. When it is intermittant, the rear light is the one that doesn't seem to work. I've checked the bulb, and it works just fine. I believe I have a wiring problem, but I don't have a wiring diagram to troubleshoot.
SOURCE: Rear Turn signal out
Are you getting power at the tail lamp assembly? Better yet, do you still need help?
SOURCE: right read blinker/break light dont work, turn signal blinks rapidly
It's the bulb. There are two filliments in the bulb. One is for when you turn your lights on and the other is for breaking and blinker flashing. When the break filliment goes bad it causes the blinker to flash very rapidly. 100% the bulb. Change it and all will be good again. P.S. if it were a fuse none of the break lights or blinkers would work.
SOURCE: Brake light, Turn signal not working rear right 06' Focus
I have a 2000 ford focus no brake lights. with the brake lights the transmission would not go into drive .replaced the brake light switch checked fuse replaced turn signal switch with no results then i moved onto the wiper switch and replaced it as much to my supp rise it fixed the problems
SOURCE: Rear blinkers and brake lights on 2001 ford focus not working
yes it sounds like the turn signal switch is defective, the brake lights go through that switch as well.
SOURCE: Right turn signal not working. Blinks very fast.
the fast blink means your bulb is burnt out back there.
