I plugged the USB cable into my computer to charge and that was around 12AM this moring and it is 12PM now and the light is still blinking orange? What is wrong?
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
my ipod shuffle wont work. it was updating the itunes 8version and i cancelled the updating, after this it doesnt show any light when connected to my pc. what should i do?
i have exactly the same problem. the light just flashes orange
i did put my ipod shuffle for charging mor then ten hours and the light still blinking orange
i had the sam problem i changed it and it still doing the same
It still does the same thing! I am not really sure what is wrong.
