The fan comes on inside the house you can hear it but no air comes out of the vents at all. please help!
SOURCE: outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
SOURCE: Why does my window air
It is freezing up. Change or clean the filter(s) and turn it off until it thaws. If this doesn't work the problem may be more serious. Usually this means it is low on freon. A technician will have to do this repair due to EPA restrictions on the refrigerant
SOURCE: air conditioner not blowing cold air
Hi Deb,
The Suction line is the larger of the two, and the smaller is a liquid line. That said the ruber you refer to is insulation and does a very important job so do not remove it . I need to know if the outside unit is clear and free from obstruction and debris? have you noted any other worring sgns lately? ie is this system constantly running?
SOURCE: fan inside air conditioner won't turn on
there are many problems it could be. first off check the breaker box to make sure hasn't tripped. call 254-722-1891 for Dallas area A/C service.
SOURCE: Air Conditioner isn't making the house cold at all
My AC works great, cold air coming out of the vent (about 63*) intake working well also. (about 76* in the middle of the day)
Think it could be the insulation?
