Compaq D70045-236 Tablet PC Logo
Posted on Mar 27, 2017
2 Compaq TC 1100 - neither boots
I've got 2 1100's -- neither boots.
One gets the 'Operating system not found' and cannot see the harddrive in the bios.
The other DOES see the harddrive in the bios but won't boot - instead I get a black screen with white blinking cursor.
I'm assuming the first has a controller issue so we'll skip that.  The second is obviously a software/drive problem. The problem for me here is that I don't have the dvd/cd dock; I have tried putting a usb dvd on but it doesn't see the usb (driver issue) -- I do have the software reinstalls - is there anyway I can install the re-install cd by pulling the drive out?
Any advice will be greatly appreciated.
Ann
Level 1:
Habit-Forming:
New Friend:
  • Contributor 20 Answers
  • Posted on May 01, 2017
Ann
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
20
Questions
Helped
8166
Points
48
You did not mention what windows version you are running. Do you have a boot disk? Also, are you pressing F2 F12 or F10 or what other option work when you first turn on your compute? Once you are in the advance mode make sure the settings in the bios is set to boot from the USB before the hard drive. If you go into advanced options, you should be able to run a scan of your computer to find errors.
Cris
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Apr 13, 2017
Cris
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
3241
Points
36
Try first to clean you memory using the eraser and put it again. Then u can use flashdrive in installing your windows. It can be that your cd/dvd drive is the problem. Hope this can help.
1 Related Answer
Anonymous
  • 116 Answers
  • Posted on Nov 16, 2007
SOURCE: upgrade ram
Here you go. I hope this helps.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=130&prodSeriesId=376810&prodTypeId=321957&prodSeriesId=376810&objectID=c00231317
My compaq tc 1100 dont recognize wireless and tells me i need to turn on a button but this doesnt have any button of wireless how can i turn on wireless?
Look for HP wireless assistant. Download it from HP at the page pertaining to your computer. On my Tx2623 there is a switch to the right, front edge.
Propleam with bcompaq tc 1100 audio driver
Driver errors.
Go into Control Panel and select Device Manager.
Look down the list of services and click on the missing sound driver, (click on whichever one is highlighted or has a sign on it telling you it is not working properly) and select Update Drivers within the drivers sub menu. Let Windows do its stuff or let the computer find it within System or System 32 directory on your hard drive. If it can't find it, let Windows find a driver on the internet or better still, download the driver from the manufacturers web site.
Hope this helps.
My hp tc 1100 will boot up it goes into scandisk hen before it starts it reboots again and it keeps on going
try pressing F8 then safe mode with command prompt after that when the windows is open type chkdsk on the command prompt. then after its finished scanning press quit, if it has an error type chkdsk/f to fix the problem.
2helpful
Pen pointer problem
you can try calibrating the pen that would probably help
Hi i m having Compaq TC1100 now there is error on starting that operating system not found how i do the things, this tc not having any optical drive
It's bloody hard. Take it to a PC repair shop. I've just done it with a TC1000 (previous model) and it takes a good 3 hours + some extra equipment/software.
2answers
"Operating System Not Found" in Compaq Tablet PC TC 1000
That means it is unable to see your harddrive. Unlike a tower computer a laptops harddrive plugs straight into the motherboard this cannot be a cable fault.
Either the harddrive has died or the motherboards drive controller has gane bad.
You will need to seek profesional help to deal with this, the only thing you can do your self would be to swap the harddrive with another and see if you get a Windows stop message, your machine would not be able to start the Windows of another machine because of hardware differences, but if you got a Windows error message at least it would tell you if your harddrive was dead or not.
Key board problem
check you keyboard in Regional settings and see that it is set to a 101 type (US or Aust) otherwise key location can change,also are you talking about Shift Keys or the Up/Down, Left/Right scroll arrows, let me know, otherwise something has gone arye on the keyboard itself.
Top Compaq Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
