Check the wires and directions, something is crossed. Make sure your pump can do both, be in auto and be used in manual mode. I think the on switch you want to wire in will activate the auto function. There should be a float switch on the pump, be sure that works as it should. The pump may be defective or have a wire crossed.
The float switch is normally wired to turn on by itself. To do this, you simply run a "hot" lead from the battery to the float switch, then from the float switch to the bilge pump. It is best if this wire has a fuse between the battery and the pump! The "negative" or ground side should already be supplied if the pump is hooked up to a switch on the dash board. IF there is not switch on dash, you may have to run a ground wire directly to the pump.
Hopefully the float switch for the Bilge pump is under the engine not the pump motor. Having an electric motor under an engine is a fire or explosion hazard Find the float switch for the motor and follow the tubing back to the pump. A replacement pump should have instructions. Only the pump intake should be in an explosive environment.
Sounds like the pump is cooked, probably need a new one. Also check the switch on the dash, sounds like it might have failed leading to over running the pump dry, overheating the motor causing a short in the motor somewhere. Boat electrics need regular maintenance, looking behind the panel with some switch cleaner in your hand is a good idea.
Disconnected all the circuits at the battery end. Reattached each circuit one at a time . I connected the hot lead first then used a fluke voltmeter on mil amp setting -used the red lead to the end of the load wire black negative end and the black fluke lead to the negative battery post -- registered the current draw and found the circuit that was draining battery then went to each device on the circuit in this case it was a bad bilge pump motor for some reason it was shorting out but not enought to blow the circuit fuse.
There's an installation manual available online. Black is negative ground; either brown or brown/white will turn on the pump. The intent is for a three way switch, connecting brown/white directly to positive 12 VDC while brown would go through an automatic switch (e.g., a float switch).
