2001 Ford Focus Logo
Venetta Posted on Jul 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2001 ford focus ac light is blinking but hot air is coming out. I just had freon put in the car one can
Is it possible that more freon is needed?
Al Narlock
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 81 Answers
  • Posted on Jul 28, 2012
Al Narlock
Expert
Level 2:
New Friend:
Greenhorn:
Answers
81
Questions
Helped
34778
Points
266
It might need another can, with ac on and controls turned to ac max the compressor should start cycling as the freeon is added. if not you might have a low or high pressure switch that is bad check fuzes incase you blew the fuse for the ac compressor
5 Related Answers
roniecon
Ronny Bennett Sr.
  • 6988 Answers
  • Posted on Jul 01, 2009
SOURCE: 1998 Ford Windstar Air Conditioning Blows Hot air.
need more info who says it dont need freon?
SANTHOSH
  • 213 Answers
  • Posted on Jul 06, 2009
SOURCE: 2001 F150 Blows hot air when AC is on.
plse switec off 2hours
Anonymous
  • 23 Answers
  • Posted on Oct 01, 2009
SOURCE: need a serpentine belt diagram for 2001 ford focus zx3 with ac
here a go
http://1.bp.blogspot.com/_CyueFe0aN9U/SQeam-_sbtI/AAAAAAAAABo/erq5IJ5-t_c/s400/88003gd1L.gif
Jonah Oneal
  • 14092 Answers
  • Posted on Feb 01, 2010
SOURCE: 2001 ford focus heater blows cold air intermittently
CHECK COOLANT MAKE SURE ITS NOT LOW.IF COOLANT GOOD THERMOSTAT BAD.
c17hydro
Greg Bernett
  • 2993 Answers
  • Posted on May 23, 2010
SOURCE: how can i add freon to my cars' air conditioner
Charging the System
  1. Lubricate the refrigerant system with the correct amount of clean PAG oil.
  2. Connect an R-134a A/C service center to the low-side and high-side service gauge port valves following the operating instructions provided by the equipment manufacturer.
  3. Set the refrigerant charge amount, and charge the refrigerant system following the instructions provided by the equipment manufacturer.
3answers
2003 ford focus no cool air is blowing out. Could it be the evaporation cord?
Make sure your blower fan is turned on and is blowing air. When you push your a/c button the yellow light should come on. If it is not blowing cool, it could be several things. Low on 134a or the control that has the a/c button on it could be bad or blown fuse, bad compressor, etc. If the air is cool but not cold the 134A is low. If it is still blowing hot, check and make sure that the clutch on the compressor is locked in. It most likely is not. Check ac fuses and ac relay, if they are good, check the 134a ,if low, refill it. This should fix it. Remember that if the a/c clutch is not locking in, you cannot add 134a because of no circulation.On some vehicles, if it is completely out of 134a, the relay will not trip and you will have to bypass the relay to provide power to the compressor to fill it. If you do all of these and it still does not work, you will need to take it to a professional. If you need to, reply back and I will give you more possibilities.(I think that you mean evaporator coil)
Could mean a stuck button? Try disconnecting your battery (remember your radio code) then work the buttons. All may return when reconnecting? If not have the air-conditioning system checked. :)
The over drive light keeps blinking and AC blowing hot air. I have changed the fuses but they keep blowing
The overdrive light blinking, possibly is indicating a faullt in the trans. Changing the fuse will do nothing for this. Unsure on AC fault.
2005 ford focus no cold air from air conditioner but gas is fine and compressor is coming on and off like it is supposed to
check to see if your freon is not leaking out buy a freon tester at any autoparts store.you may need freon two three cans or more turn on your ac full blast and put the freon in remember use the low pressure line not the high pressure ok good luck
1helpful
2001 ford focus low side ac is too low
dear sir,
i think its low gas problem then please contect to car air conditioner technician for refilling the freon gas.
i hope answer the question,
thank you.
please vote!
1helpful
When I turn on the A/C the light will blink, compared to normally staying on solid and not blinking. The A/C blows out hot air now. What is the problem?
Well,this is telling you ,the ac needs attention,first guess,is,that the freon is to low for the ac to come on,or it is empty of freon,have the ac checked,and then make sure they put in u-v-dye to detect the leak when it does leak down again.If this was helpful,at all,please rate,thank you.
Aiconditioning blows hot air Ford Focus 2004
Your valve that shuts off the hot water to your heater core is not closing.Your AC is running but it is trying to cool down 200Deg. air.May be a issue with the heater/AC contol in the dash or the mixing valve stuck open.
2helpful
2answers
How do i charge the air conditioner on a 2000 ford focus. Where are the connectors
Look for the ac compressor,and locate the large ac line coming off the ac compressor.Follow it until you come to the ac charge port.this is where you charge it up with a charge hose that you have.Put the can on the can tap,and the quick connect to the ac port on the ac.Turn the t handle on the can tap clockwise until all the way down.hold the can upside down.start engine and turn the ac on high blower.and recirculate.shake can lightly,until the can empties.Turn the t handle counter clock wise,almost all the way out,and remove the can .Repeat to add another can,Don`t put too much freon in,and add ac oil also.If it lost freon,it lost oil,failing to do this could cause the ac compressor to lock up.One 4 oz can will be fine.look for the large ac line to get cold,and the accumulator to get real cold,then stop with the freon.
6helpful
2answers
Where do i put freon in on a 2005 focus
Your focus should not take freon. Freon is used in older cars from 1995 on back. Your focus should take R134 and the plug for your AC should be located under the passenger side wheel well (yes ford makes things so convenient). Just unscrew the little plastic crews in you wheel well and attach the gauge and can of R134 (should take a little more than 2 large cans).
2005 Ford Focus AC problem
I had this probelm, my air conditoner was low on Freon, try getting it serviced. I only had 1/2 lb of freon in my system.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
