How do you reset the oil change?
From Kia's website.
"If you would like to reset or inactivate the maintenance system press
the RESET button for more than 1 second. The display will change to "Engine Oil Service Message" mode.
You can move to items by pressing the TRIP button and select the desired item by pressing the RESET button."
SOURCE: gear box oil filler plug - kia rio 2004
you have to take off the speedometer cable/wiring harness from the top of the trans and fill it from there....one 10mm bolt...very awkward spot...it might be snug, so just take a flat head screwdriver from underneath to tap it loose...
SOURCE: resetting airbag on 2002 kia rio
reset by code reader but you may have a problem warning lights dont come on for nothing also if you have seatbelt restraints these are connected and it may be one of those, hope its of help.
SOURCE: 2003 kia rio I changed the fuel filter the car
had similar problem, 2003 rio 1.6l idle fine and die when trying to accelerate or lurch and die ran fine in reverse change timing belt,wires plugs, had codes for multi cyl misfire and low injector voltage, still same lurch and die. try wiggle test on sensor plugs and main engine harness between battery and engine . i did this and found car smoothed out,tried wiggle again and car died,took harness apart where i wiggled it and found broken wire to crank sensor.good now
