Hey my cars been acting up so i did the diagnostics scan and it read, 1...08 and i have no clue what that means and all the diagnostics ive read from people all look different than mine... any help please?
Here is a diagnostic trouble code table for your refer. diagnostic trouble table.
What kind of diagnostic you use? You can visit this website, a very technical OBD2 diagnostic supplier, and may have some help to you.
SOURCE: saab 95 headlights dont work high work and drive lights stay on
IF THE BULBS ARE OK CHECK THE HEADLIGHT MODULE(IT LOOKS LIKE A RELAY, ORANGE CASE I THINK) TRY WIGGLING IT,IM PRETTY SURE THATS IT. THEY GO BAD ALOT ON SAABS. IT SHOULD BE IN THE ENGINE CONPARTMENT
SOURCE: can a flat battery on a 99 saab 95 put the car in limp mode ?
have the guy to put a new battery on the car then try it.I would not buy it if he is not prepared to do that for you.The car only goes int limp mode if you have a bad fault.I doubt its the battery i haven't come across this before just because you have a flat battery
SOURCE: 1999 Saab 9-5 AC/heater blower fan not working
Check your fuses. if all is well, more than likely it is yor fan motor
SOURCE: I have a check engine light and I am reading two
Don't know if it is any help but I had the same problem and it turned out to be the intercooler hose was split and sucking air. Fixed it and know problem now.
SOURCE: WHAT DOES ENGINE COE P502 MEANS ON A 2000 SAAB 93
The Code you're referring to should be a "P0502." What the Code signifies is: "Vehicle speed sensor circuit, low input."
