hi Mustafa.
The highest IQ was 228, according to Guinness Book of Records, this score belongs to the 'smartest' person in the world Marilyn vos Savant who scored it when she was 10 year old. This would, according to recent research, correspond to about IQ 185 at adult age. List of people with the highest IQs ever recorded (in ascending order)
I'm a MSI guy myself. I would go with the Z97. As for the processors, I would save the extra $150 to $200 and get the 4790k. Plenty of power, and you save some money on it. Use the left overs to purchase a good set of ram. Intel Core i7 4930K vs 4790K
Has a built-in GPU
Yes
vs
No
Somewhat common; A separate graphics adapter is not required
Higher clock speed
4 GHz
vs
3.4 GHz
Around 20% higher clock speed
Higher turbo clock speed
4.4 GHz
vs
3.9 GHz
Around 15% higher turbo clock speed
Lower typical power consumption
71.5W
vs
105.63W
More than 30% lower typical power consumption
Better PassMark (Single core) score
2,535
vs
1,995
More than 25% better PassMark (Single core) score
Better cinebench r10 32Bit 1-core score
8,785
vs
6,903
More than 25% better cinebench r10 32Bit 1-core score
Higher Maximum Operating Temperature
74.04 Ā°C
vs
66.8 Ā°C
More than 10% higher Maximum Operating Temperature
Better performance per dollar
4.97 pt/$
vs
3.93 pt/$
More than 25% better performance per dollar
Newer
Apr, 2014
vs
Jul, 2013
Release date 9 months later
Lower annual commercial energy cost
77.09 $/year
vs
113.88 $/year
More than 30% lower annual commercial energy cost
Lower annual home energy cost
21.2 $/year
vs
31.32 $/year
More than 30% lower annual home energy cost
Basic foosball rules include: ā¢- First one to serve is determined by a coin toss. ā¢- First team to reach 5 goals wins. ā¢- Players cannot spin the rods. ā¢- The team that gets scored on gets to serve following the goal. ā¢- If the ball gets off the table, the team that last scored gets the ball. ā¢- Players can have the ball at one place for a maximum of 15 seconds. ā¢- If there's a "dead ball", last team that scored gets the ball. ā¢- Timeouts can be called only during ball possession.
The highest score possible with three darts is180, commonly known as a "ton 80" occurs when all three darts land inthe triple 20. There are many different types of dart game and the maximumscore changes from each one.
there is many kind of brake system of ur truck here i will send u everything about the brake and i hope its help
Rear Brakes JC3
Rotor Discard Thickness*
18.50 mm/0.728 in
Rotor Minimum Allowable Thickness After Refinish
19.0 mm/0.748 in
Rotor Thickness (new)
20.0 mm/0.787 in
Rotor Maximum Allowable Lateral Runout
0.05 mm/0.002 in
Rotor Maximum Allowable Scoring
1.50 mm/0.059 in
Rotor Maximum Allowable Thickness Variation
0.025 mm/0.001 in Rear Brakes JC4
28.50 mm/1.122 in
29.0 mm/1.142 in
30.0 mm/1.181 in
0.05 mm/0.002 in
Rotor Maximum Allowable Scoring1
.50 mm/0.059 in
0.025 mm/0.001 in Rear Brakes JH2
28.50 mm/1.122 in
29.0 mm/1.142 in
30.0 mm/1.181 in
0.05 mm/0.002 in
1.50 mm/0.059 in
0.025 mm/0.001 in Rear Brakes JH6
27.50 mm/1.082 in
28.0 mm/1.102 in
29.0 mm/1.141 in
0.05 mm/0.002 in
1.50 mm/0.059 in
0.025 mm/0.001 in Rear Brakes JH7
28.5 mm/1.122 in
29.0 mm/1.142 in
30.0 mm/1.181 in
0.05 mm/0.002 in
1.50 mm/0.059 in
0.025 mm/0.001 in * All brake rotors have a discard dimension cast into them. Replace any rotor that does not meet this Specification. After refinishing the rotor, replace any rotor that does not meet the minimum or discard thickness specifications.
