My car was fine last night, parked it to go buy something in the store came back out and wouldn't start. The secuirty light keeps flashing, we push started the car and it will start and run for about 3 seconds and will shut back off.
SOURCE: car starts run's 3 seconds shuts down
Your car is equipped with a system called PASSKEY standard on all GM cars and light trucks, try the following procedure to reset the system, the battery being dead will trigger the system.
PASSKEY LOCKOUT RESET GM CARS 1999 UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the passlock system to recognize your key.
SOURCE: Car won't start - anti-theft light flashing
it sounds like the immobilizer is faulty. this will shut off the electrical feed to the starter motor. you will need to take it to a garage to get this fixed.
hope this helps.
SOURCE: 1993 pontiac bonneville won't start when security light is on
Here is a detailed write-up on how to bypass the entire VATS security system yourself.
http://newrockies.ca/vatsbypass
This is what saved my car and my money (that I didn't have!).
SOURCE: Car is stuck in park. Wife drove home last night
TRansmission went on the car you may have to buy a new transmission
