Turn key to start engin, nothing hapens, no sound, nothing. The guages on dashboard do not move, dome light, head lights, radio work.
If you had said the radio did not work, I would say it was the key switch or a large fuse or fuseable link.
But the radio is powered thru the key switch.
The problem could still be the key switch or a major fuse, I would check all of the fuses then power at the key switch.
Also check the ground connections.
SOURCE: Can I bypass the Passlock security system?
never heard of this happening before ,sounds more like the code reader behind the steering lock is playing up.If it is then its dealer only,have a funny feeling this could be an expensive repair.Sorry i couldnt be much more help but this fancy electronic stuff is designed to stop general mechanics like myself from doing repairs.
SOURCE: My 2001 Olds Integre will not start, but later does start.
This may be a problem with the ignition switch. The ignition switch feeds power to many of the different systems- including the starting system and the dash.A low voltage output of the switch will not allow the starter relay to engergize, along with many other odd problems. A way to check this is that when it is acting up, turn the ignition key back and forth very quickly many several times, or tap and the head of the key with a small hammer. These things will normally cause a faulty ign switch to correct itself for the time being.
http://www.greatautohelp.com/more_oldsmobile_questions.html
SOURCE: 1997 oldsmobile cutlass supreme
This Too Is A Starter Problem, If >>The Battery Terminals Are Clean <<And >>The Starter Terminals Are Clean and TIGHT <<,I Would Wait Till It Wont Start Again and SMACK THE STARTER 2-3 times with a HAMMER then Try Starting it. If It Starts then it is The Starter. I KNOW this seems A Little UNCONVENTIONAL BUT For 30 Years This Technique Has Diagnosed HUNDREDS of STARTER Problems for me.
SOURCE: Alero Interior Lights Will Not Turn Off
a bad control module.it controls inside lights and door locks.
SOURCE: turn the key and nothing happens,no crank,no sound,no start
It seems that you have a loose wire, bad connector or perhaps the main computer itself that is causing a problem If the shop is not seeing any codes, or codes come and go, likely I'm right...but someone is going to have to actually do some intensive testing to find the real cause. You can likely get another computer from a local scrapyard far cheaper than what the dealer will charge you...as far as wiring, you need a good accurate schematic a good volt/ohmeter and lots of time to trace wiring. When checking connectors test the pin, then probe the wire going into the pin...often the problem is where a wire meets the backside of the pin, either corroding or breaking..This also applies to any modules such as the security system...what you see on the dash does not always tell you that connection to components is good. This is not a "fix, but rather, a direction to go in. (exactly what I"d need to do if I was there)
Right now, everything is suspect including fuel system, till you rule it out!!!
