Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sounds like it's a motherboard or processor issue. Why, well when you said it's slow and freezes, sounds like either the motherboard or processor (I've had this issue with both) and as a long shot it could be a hard drive dieing.. (stops spinning intermittently)
Does the after market adapters have the same voltage and at least the same amp. rating (can be more) as the original Dell adapter?
If they have less amps then it would explain why they are burning out because they are overloaded.
If the adapters are equivalent or better than the original DELL adapter then there is something wrong with the laptop which is causing it to draw more power (amps) than normal and it needs to be checked out.
it looks like the battery is defective. try reseat the battery while the power cord plug in to see if that help. if you remove the battery and leave the power cord plug in, the battery symbol indicator light will turn off. Time to order a replacement battery.
