is it a manual gearbox? can you put it in 5th release the handbrake and rock back and forth it to see if the engine turns? if its an auto you will need to use a large spanner on the engines bottom pulley. that way you will see if it is seized and then if the oil pressure - level is relevant.is it a manual gearbox? can you put it in 5th release the handbrake and rock back and forth it to see if the engine turns? if its an auto you will need to use a large spanner on the engines bottom pulley. that way you will see if it is seized and then if the oil pressure - level is relevant.
Re: Why won't my 92 jeep start? Ihave a new battery...
Maybe earth strap to chassis from engine. put a multi meter from battery neg to engine, set it to DC volts and crank the engine. should read 0 volts if ok. will read about 12 volts if earth is knackered.
With a voltage meter see how many volts are at the starter terminal. If not 12+ volts you have a bad connection. Check connection at the starter solenoid. Does it have 12+volts? Short the solenoid. Does it put voltage to the starter?
I take it that it cranks over but will not start. Spray some starter fluid into the throttle body. If it runs, you have a fuel problem. You may have disconnected the fuel system by unplugging a connector or grounding a wire blowing a fuse.
I'm more up for battery-chassis earth strap or chassis-engine earth strap.
