First Option: Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So Secend Option: Your Phone Network IC Fault So Please change Network IC And Network Signal Problem will Solved if it is there isn't much you can do on this side of the network. Contact your phone company.
Its probably damaged the board in the phone but it may have just gummed up the charging port remove the battery and clean the charging port and the battery contacts and phone to battery contacts using rubbing alcohol and que tips. Hope this helps Chris
