SOURCE: lighting problem fiat punto
Then there will be some wrong connection of wire
between the indicator and the break light.
thanks..
SOURCE: Fiat Punto indicators
you need to change the flasher unit .... also check fuse # 24 on the fuse panel inside the vehicle. the flasher unit should be just under the dash on the steering wheel side... i have alot of information on that vehicle but i couldn't find where exactly the flasher unit is located.
Robert
SOURCE: fiat punto acceleration problems
nikki,
I had a similar problem with a 98 sporting. It turned out to be firstly the clutch had worn down to almost nothing and the fuel filter hadn't been changed in a good while so it got clogged. I would do the filter first. (located just under the drivers side near the rear wheel.
SOURCE: fitting a wing mirror on the passenger side of a fiat punto
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Hello
The engine
and transmission in this cars drive train are fully
electronically controlled by a computer called the PCM (Power Train
Control Module). Whenever a problem like this occurs the computer
stores a record of the problem (there are of course some exceptions
to this, like the fuel pump for instance) in the form of a fault code
in its memory, to read these fault codes you must have the systems
memory scanned with a special tool. Once the fault code(s) are read
you then must perform the appropriate diagnostic testing to find and
resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL THE
DIAGNOSIS & TESTING IS COMPLETED.
