I have all power,lights,fans,2 cd drives,1 does read disc,1red light on MoBo,no screen at all., beeps non stop.????
Hello here is the homepage:
http://www.biostar-usa.com/mbdetails.asp?model=m7mia
Try to change the ram modules, or it could be the power supply failing.
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Look also here:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Good luck
SOURCE: on first power up, no video, no sound.
hi
*********** board dead
hope ur smps &ram also ok ......
pl z check motherboard near pc service care.......
SOURCE: cd for BIOSTAR BI8600GV Intel 865 chipset mother board lost
http://www.motherboard.cz/mb/biostar/P4TSV.htm
I think you will find all you need there ...look carefully to be the exact same model if you want to flash the bios...otherwise its safe
SOURCE: NEW BIOSTAR MOTHERBOARD DOES NOT BOOT
Good day sir, let try to test first the power supply, Unplug the power cord, remove the 20 pin (24 pin for the late model) molex power connector from the motherboard, plug in the power cord, get a 2 to 4 inch jumper wire, short the green wire with any of the red or black wire on the molex 20 pin power plug, the result maybe the following:
If in case you are with #1. uinplug the power cord and remove all the expansion cards, data cables from the hard disk and cd drives. we are trying to isolate the problem. make sure that the only connected cables on the motherboard are as follows:
Test the pc once more. plug in the PC. If still the board wont power on. problem with your motherboard. Note:make sure your RAM is good. Hope this helps.
SOURCE: Just replaced my Biostar P4M80-M4 mother board
Try replace the Memory module (DDR2 RAM) with new ones.That's should fix it!!
If still won't come out, replace the power supply unit.
SOURCE: My client has a p4m900-m4 mobo that was installed
Hi
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or HDD or whatever as long as it's a drive) the CPU, graphics card (if required) and one bank of memory, unless the board requires dual matching chips.. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drives, make sure you set your pin settings for master/slave/CS are set correctly on it. Now, you should get the power supply on, and the cpu fan spinning. If those don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card or finally the motherboard. The next step is to replace each one of the elements with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that. I usally start with the drive, then move to the memory chip, next CPU, Last PSU. I also make sure that my replacements work on another machine first. If no change, then it's save to say you have a bad Board. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Please don't forget to leave a rating.
Thanks Mark
