1997 Ford Crown Victoria Logo
Matthew Voller Posted on Jul 08, 2017
'97 crown vic cranks but stalls immediately
It cranks just fine but the second the starter disengages, the car quickly stalls. ive tried giving it time to warm up by giving it a bit of gas but even after 3 minutes of this, the second i take my foot off the gas, it stalls. it doesnt run rough. the smoothest idle ive ever felt even at 200 rpm. im thinkin maybe low fuel pressure but i dont have the right fitting to put my pressure gauge on. help would be greatly appreciated!
  • Jeffrey Turcotte
    Jeffrey Turcotte Jul 08, 2017
    Hi Matthew Voller, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Have you checked the idle air control valve?
Terry Huffman
Level 1:
  • Contributor 36 Answers
  • Posted on Nov 18, 2017
Terry Huffman
Contributor
Level 1:
Answers
36
Questions
0
Helped
10434
Points
77
Idle air control valve. And/or gunked up throttle body, pcv port at throttle where mating to intake manifold.
4 Related Answers
Matthew Boulden
  • 440 Answers
  • Posted on Jun 23, 2009
SOURCE: 1988 Ford Crown Vic Strange Idle
When you turn the key on does the check engine light come on? If not it may be burned out. It sounds like a MAP sensor or an O2 sensor is bad. I would suggest taking it to autozone as they do free diagnostic and seeing if a code comes up. If it is a sensor it should, if not it may be the idle sensor not reading right in the ECU. More than likely it is one of the sensors though.
Anonymous
  • 6 Answers
  • Posted on Jun 27, 2009
change the egr vavle !!!!!!!!
Anonymous
  • Posted on Oct 06, 2009
SOURCE: 1988 Ford Crown Vic Strange Idle (Getting Worse)
i am trying to install an aftermarket temperature guage with capillary tube into my 1988 crown victoria ltd 5.0 efi. where does the capillary tube mount?
Anonymous
  • 89 Answers
  • Posted on Oct 08, 2009
SOURCE: my 1985 ranger 2.3 gas FI 4x2 starts and then
Did i answer you before? Anyway, try cleaning the throttle body with a little carb spray on a cloth shop towel wraped on a screwdriver.With the engine off,remove the tube to the t-body,hold the throttle alittle, and spray a couple of squirts inside.Spray some to wet the towel, and pushing it in and out gently of the t-body.becareful not to bend the plate inside or leave any towel inside.look at it with a flashlight to see if it's clean. Hope this helps
My 1986 ford crown vic selinoid is clicking
Either the solenoid/starter is ad, or the battery is too weak to engage the starter. You can try a jump start to see if the battery is too low. A quick test is to turn on the dome light. If is goes out when you crank the starter, either the starter is drawing way too much current or the battery is too low to crank.
1helpful
1999 crown vic wont start
Are you saying it won't crank, or won't start ?
If it does not crank, and you have replaced the battery and starter, the problem may be in the neutral safety switch.
99crown vic wont crank put code in door lock
find the fuse fo the keyless enter and take it out and that way you will know if that the problem or something else give these websites a try www.autozone.com and www.alldatadiy.com cause the keyless enter will short out sometimes wish you the best of luck Michigan Man.
3answers
3answers
1992 Crown Vic wont crank
Check the starter solenoid. Usually mounted on a fender well. Find by following the + battery cable.
97 ford crown vic wont crank
if it wont crank check the battery/cables then check starter also check fuses to starter
2answers
1992 crown vic 4.6l
did you check the inertia switch?? that's what happened to mine
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
