SOURCE: need to know btu of
Hi, this is a Rheem 2 ton unit. For each ton of cooling, there are 12, 000 btu's. So your model number is a 024, that equals 24,000 btu's of cooling. Please don't forget to rate me on this. Thank you.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
SOURCE: we installed a 4 ton
you have a missmatched system, for it to work try removing the orfice on the high side txv it is not allowing the evaperator coil to fill with refrigerant properly coleman and intertherm dont like each other since they control a large market in the manufactured housing heating and cooling units electricaly connecting the componets together no issue prefromance sometimes is the issue hope this helps
SOURCE: coil piston
If you purchased it as a package the right piston may already be installed in the indoor Evaporator coil. When shipped the extra piston if needed is packaged with the outdoor section condensing unit.
SOURCE: need recommended sub-cooling and superheat for
Superheat should be 8 to 12 degree's. Sub cooling around 18-22. I like to use superheat that way I know the coil is doing all it can do.
SOURCE: I am thinking about purchasing a Ruud UANL -024JAZ
All brands have issues at some point. You should be satisfied with RUUD.
