When gears could not be selected while running, I replaced flywheel clutch and pressure plate on 2004 VW Touran now 1st, 3rd and 5th gear (grinding on fifth) difficult to engage. Neutral is now sitting halfway between where neutral used to be and these 3 gears. Any ideas on how to fix this. This is a 1.9 TDI motor AVQ with 6-speed manual gearbox (02S I think) The car is drivng well though just the grinding in 5th and the new position is unnerving
SOURCE: in my 1998 VW golf i lost use of 1st. 2nd. and 5th
yes. you have to check the plastic/rubber moulding at the linkages under the hood. maybe one of them is missing (fallen out because of wear)
SOURCE: VW GOLF 1.4 1999 S. Gearbox makes whining sound at idle
No good news on this one I think
Your whining sound problem is the Layshaft bearings in the gearbox are
badly worn. It also seems that the baulk rings are damaged on 5th gear.
John
SOURCE: my ford focus tdi 2003 cant select 1st,3rd or 5th gears.
Car is in limp in mode unless you have the tools to work on automatic transmission you will need to take it to a transmission shop. Of course you can check oil level but I suspect you have other issues.
The problem has been solved: first we released the cable linkages by following this example: Volkswagen Group: Shift Linkage Adjustment for year models 2000-2010 (search on you tube) this still did not work as well as we'd liked, so we took the nut off the chrome part (where the linkage rotates on) lifted the mechanism off the bolt and rotated one spline in the required direction. The gears work like butter now.
