Cobra 29 LTD CB Radio Logo
Anonymous Posted on Jun 20, 2012
Cant find vr4 on my cobra 29 made in vietnam
Ive looked for the vr4 mod control on my cobra 29 ltd classic made in vietnam and cant find it anywhere is there a different number on this model?
  • Anonymous Jun 20, 2012
    their is no vr4 on my cobra 29 ltd classic its made in vietnam. ive looked everywhere and cant locate it
Dan
Level 1:
New Friend:
  • Contributor 41 Answers
  • Posted on Dec 21, 2013
Dan
Contributor
Level 1:
New Friend:
Answers
41
Questions
0
Helped
12815
Points
62
With the covers removed and the front of the radio facing you with the component side up, You will see a transformer with yellow,blue or red colored tape around the center. VR4 is located to the left of that. If you still can't find it, then remove D11 to open up the audio.
4 Related Answers
Anonymous
  • 68 Answers
  • Posted on May 10, 2008
SOURCE: Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
Anonymous
  • 6966 Answers
  • Posted on Sep 08, 2008
SOURCE: Cobra 29 Ltd
Appreciate the direct "Ask Me" again.
The initial posting would still hold true, best would be:
  • remove TR18;
  • replace 2SC2069 with 2SC1969; and
  • adjust L12, 13 & 14.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Anonymous
  • 773 Answers
  • Posted on Apr 24, 2009
SOURCE: cobra 29 ltd classic antenna calibration ??
Wow. That's not at all a solution to what this guy is asking. And why all the caps??
The one point jm77437 has that is correct is that you do not set the radio, you set the antenna. The rest is blah blah.
Here is how you tune your antenna for you radio. First off it depends on what kind of antenna you have. most fiberglass antennas have a tunable tip to adjust the height of the antenna. Metal whips either have a collar at the base that the whip will either slide up or down in to adjust the height. The other type of metal whip's you have to physically clip to shorten the antenna, you must be careful with this type because once its clipped, that's it. You cannot add what you cut off.
I am going to give this example using a metal whip with an adjustable collar.
First after your radio is hooked up in the vehicle, drive to an open lot. Buildings and other structures can cause extra reflection. turn to channel 1. Flip the meter to CAL. Key the mic without talking. Now turn the CAL knob up until the needle reaches the little upside down triangle all the way to the right marked CAL. Now you have just celebrated your radio for your setup to measure you SWR. Now while still holding the key, flip the meter switch to SWR. The needle will move, and where it stops is your SWR reading. The lower the better. Anything under 1.5 is considered really good. But still, the lower the better.
Make note of what your SWR was on ch 1.
Now flip to channel 40. Repeat the SWR process. You must recalabrate each time you take a reading.
Now like jm77437 said. If your SWR reading is higher on 40 then 1, then your antenna is too long, and you must make it shorter. Loosen the collar and lower the antenna in the collar 1/4 inch at a time. check the swr each time you adjust the antenna.
If your SWR reading is higher on channel 1, then your antenna is too short. You must make your antenna longer. Do this by loossening the collar and pulling the antenna upward in the collar 1/4 inch at a time, again checking the swr each time you adjust the antenna.
What you want to achieve is having the same SWR reading on channel 1 and 40. then you have the best match you are going to get with that antenna.
If your swr is under 1.5 on all channels, you don't need to fuss unless you are a perfectionist. then by all means go ahead.
If your reading is higher then 3, or your ant light comes on, something is really wrong. Make sure your antenna is connected all the way, and the coax is not damaged.
Its important to have an appropriate SWR because if you do not, you are reflecting too much signal back into the radio, and eventually you will burn out your final transistor, and your radio will be toast.
Some tips: make sure you check the swr with the doors and windows shut. Make sure you are in an open lot. Remember to calabrate ecah time you take a reading. If you have had your radio peaked by a radio shop, and they have lowered your dead key, or have done a swing modification, then the meter in your radio will not work when taking an SWR reading and you will have to use an external meter.
Anonymous
  • 773 Answers
You should not calibrate the antenna before you install it on the car!! the antenna needs to be calibrated on the vehicle that it is going to be on. Type of vehicle, different mounts, and many other variables can change the amount of reflection you will get.
j0hn9999 did a much better job but left some info out.
Take your SWR readings on channel 1, then on channel 40.... NOW, if your SWR is higher on ch 40 then ch 1, then your antenna is too long and it needs to be shortened. Refer to the antenna instructions on how to shorten the antenna.
If your SWR is higher on ch 1 then on ch 40 then your antenna is too short. You must lengthen the antenna. Again refer to your antenna instructions on how to lengthen your antenna.
You must calibrate each time you take a reading.
Make sure your doors and windows are shut when taking a reading
Make sure you are in an open lot when taking a reading as buildings, trees and other structures can cause reflection and give you an inaccurate reading.
If you adjust the length of your antenna on another vehicle and then put it on yours, the SWR will be off. It will need to be tuned again.
An external meter is better then the one in the radio, but will need to be hooked up in the vehicle you have the antenna on.
If you are not running any kind of power, or do not have a swing kit installed, and the radio is stock, the meter in the radio is more then enough to get a correct SWR reading.
Cobra 29 ltd classic no modulation
check VR4 to make sure it isn't closed . Check D 11 to make sure it isn't clipped . Turn VR 4 clockwise till it stops then back it off a little .If D 11 is clipped replace it with another diode then try it again. If it doesn't work it could be your final or your driver so replace both..
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Unidenpc78elite modulation adjustment point
the uniden 78 series is like the COBRA 29 ltd not the cobra 25 . the pc 68xl is like the 25 ltd The Mod..adj point on the 78 is VR4 .
Where is vr4 in a cobra 29ltd classic
near the middle of the board at rear of radio----hint: all the controls on the board are actually marked with the VR numbers, so just take a look.
1helpful
I just purchased a Cobra 29 ltd classic. Trying to find the potentiometer vr4 but all pots are labeled r1, r2 ect. Which one is it on the newer radios. thanks
Some time ago I had need for info. for a 149GTL Cora and went to this Email ad..............http//www.superior.net/~haggis/smods1html. Good luck with you're research.
Cobra 29 LTD Classic not transmitting or receiving
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
1helpful
Cobra 29 Ltd
  • remove TR18;
17helpful
2answers
Cobra 29 Ltd Classic
In most cases just turning up VR4 is more then enough. Replacing the final, tr14 with another transistor requires changing many more parts to get it to work.
With a new 29, there is no need to change the final. Just turn vr4 all the way up and you will see around 20 - 25 watts. L13 won't gain you a single watt. L12 will raise the dead key, and usually you want a lower dead key for good swing. L14 will gain you a few watts, but don't adjust this unless you have a watt meter. You turn it out to increase wattage, but too much will over bias the final and shorten its life.
You hook it to a watt meter with a dummy load. Then say a steady AHHHH into the mic while keyed. Turn the slug out until the needle stops going up, then back it down to where it stopped.
The easy thing to do, and you will be pleased is just to turn VR4 up. Now, Up is counter clockwise. Its a variable resistor, so the less resistance, the more modulation. So you want to turn the VR down.
that will be more then enough.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
