SOURCE: I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
SOURCE: i'm looking for a stereo system wiring diagram for
Sir,
Click this link for wiring diagram. If it is not your model let me know
Thanks
Good Luck
Appreciate to rate as "Fixya"
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems related to factory installed systems not add
on aftermarket systems.
This post
can't be removed or moved, please re-post the question in the correct
product category. Thanks
INCORRECT PRODUCT CATEGORY
I'm
sorry but I believe you have this posted in the wrong product
category? Please re-post the question in the proper category if this
is the case, otherwise you have my apologies. This is the car and
truck problem category
